Best Place to Buy Timing Belt & Water Pump Kit
Subscribe
May 23, 2011 | 05:24 PM
I just purchased a B6 A4 3.0 w/ 91k miles and from what I've been reading, it looks like I need to get my timing belt replaced asap. Also read that it makes sense to replace the water pump as well if the timing belt is getting replaced. From everyone's vast experience on this forum, where is the best place I can buy a timing belt & water pump kit?
The best price I found online is $389 incl. shipping and that seems a bit steep.
Any feedback is appreciated...thanks everyone.
Reply
May 23, 2011 | 05:29 PM
Powerseller on EBay?
Just found a timign belt & water pump kit on EBay from a Powerseller. It will be $291 all in with shipping.
http://cgi.ebay.com/ebaymotors/2002-...mp-/3704977995
Should I get it?
Reply
May 24, 2011 | 08:35 PM
Try www.blauparts.com I've never purchased from them yet but I do much forum surfing and always see them mentioned. They have instruction set as well for DIY and additional parts you should change while your at it. Here's the link to the B6 3.0.
http://www.blauparts.com/proddetail.asp?prod=GH21119-A
Hope that helps
Reply
May 26, 2011 | 05:28 PM
Blauparts have always been good to me. This is the kit I'm going to buy and have my mechanic use: http://www.blauparts.com/proddetail.asp?prod=GH21119-1A
Reply
May 31, 2011 | 04:10 PM
There are a number a specialty tools required to do this job properly which can cost just as much, or more than, the parts. It's worth purchasing from blauparts for the tool rental alone...
Reply
Jul 16, 2012 | 06:17 PM
water pump leaking
I have an audi A4 2006.. the problem is that the water pump is leaking.. i am told that the water pump alone cannot be replaced.. the timing belt has to be replaced with it.. is it so? please let me know if only water pump can be replaced and the approx cost of repair.. thanks in advance
Reply
Jul 17, 2012 | 01:08 AM
I'm lazy and having pure motorsports replace all of that for me, thermostat, water pump timing belt, serpentine belt etc, etc.. Total cost $900ish which isn't bad, considering Audi would probably charge me $2000 plus, and a Audi/Porsche specialist was going to charge me $1500. I'm paying roughly $500 for convenience, and I don't care, I don't feel like doing it again.
Reply
Jul 17, 2012 | 01:16 AM
Quote: I have an audi A4 2006.. the problem is that the water pump is leaking.. i am told that the water pump alone cannot be replaced.. the timing belt has to be replaced with it.. is it so? please let me know if only water pump can be replaced and the approx cost of repair.. thanks in advance
You don't have to replace the timing belt, it's just recommended because of the work that's involved in replacing the water pump. It's kind of, you're in there, you might as well replace it.
here's a look. DIY: B7 A4 Timing Belt Change
Reply
Jul 17, 2012 | 02:35 PM
We have complete timing belt kits available below!
Click HERE to order or for more information.
Let me know if you have any questions.
Jason
Reply
Jul 17, 2012 | 05:54 PM
Quote: You don't have to replace the timing belt, it's just recommended because of the work that's involved in replacing the water pump. It's kind of, you're in there, you might as well replace it.
Thanks fire5414!
Could you please tell me about approx costs of replacing the water pump alone, timing belt alone and both together?
I have people quoting from $800 to $2000..
Your help is greatly appreciated!
Reply
