Bosch 380cc injectors good for stage 1+
Old Apr 11, 2008 | 01:18 PM
cbehr's Avatar
Default Bosch 380cc injectors good for stage 1+
Like the title says...I never read any info on people using these? They are not the TT 225 injectors, just Bosch 380cc's
Old Apr 11, 2008 | 01:38 PM
rccks96's Avatar
Default RE: Bosch 380cc injectors good for stage 1+
See my sig.
The genesis 380cc's are fine.
Old Apr 11, 2008 | 01:39 PM
cbehr's Avatar
I'm talking about Bosch 380cc's though....
Old Apr 11, 2008 | 01:42 PM
MyUltraSport's Avatar
I have the APR Stage 1+, and APR installed the Bosch 380cc's in my car and they have been fine for quite some time now.
Old Apr 11, 2008 | 06:06 PM
cclazer's Avatar
Member
What about 550cc injectors with the APR chip??? Or is it tuned just for 380cc?
I saw that they have 2 different options when selecting your chip mod: 1 or 1+(which, by description, seems to just come with the injector set for $500 more). Is the only diffence between these two options the included injectors, or is the chip different?
I'm just wondering if their stuff will work good, or if I need to dyno tune instead.
Old Apr 12, 2008 | 03:36 PM
if you don't plan on upgrading your turbo, the 380cc injectors are more than adequate for the stage 1+. But if you intend to get a big turbo (stage 3 or bigger) you'll need larger injectors. I think the 380cc injectors are even fine for a K04 turbo.......which is a waste of time, if you are going to stage 1+ on a K03 (really the same power gains).
Old Apr 12, 2008 | 04:42 PM
PandaXpress's Avatar
u might run rich if ur injectors are way to big
i thought APR only uses TT225 386CC injectors
Old Apr 12, 2008 | 04:43 PM
cclazer's Avatar
Member
The turbo I have been looking at isa gt35. But even without out that, just the k03 and 550cc injectors, is the apr chip tuned to useany injectors? Or just 380cc?
Basically, if I have 550cc injectors, would I be wasting time with the APR chip?
Old Apr 12, 2008 | 04:50 PM
ORIGINAL: cclazer
if you are askin question like this i dont htink u should be goin big turbo casue theres alot u should know befor u get ur self into something like major engine mods
yes you are wasting ur injectors
but u do kno if u have stage 1 apr u CANT just throw in the injectors rite
you have to get the stage 1+ programming which is the same price
or if u already have stage 1 programing u have to upgrade it which is free or something, you might have to pay for labor depending on the placeyou just need the injectors
they also recommend a FMIC
Old Apr 13, 2008 | 11:21 AM
cincyTT's Avatar
I'm make believe
A larger maf housing would help with the larger injectors, but that would be a waste since 550cc is no where near large enough for a 35r. 550cc will getyou close to 400whp.
