Brake light beeps and flashes when turning.
Old Jan 2, 2009 | 12:50 PM
il laureato's Avatar
Cool Brake light beeps and flashes when turning.
My brake light in the dash flashes and beeps when turning right. It appears to be more sensative when the temparature is colder. My rotors and pads appear to be fine. I haven't checked the brake fluid, but I would assume the info screen would inform me that is low. Any thoughts or suggestions??
Old Jan 3, 2009 | 10:06 PM
info@a4mods's Avatar
is it the light that says 'brake' or is it the one in the DIC which indicates brake wear...
Old Jan 4, 2009 | 01:00 AM
borninrussia3's Avatar
check the connection on the sensors
Old Jan 4, 2009 | 02:09 AM
if it is they light that glows red and says 'brake', then it it not the wear sensors. The wear sensors show up as the icon in the DIC. I believe it looks like circle with a squiggly line through it
Old Jan 5, 2009 | 05:13 PM
ohhh yeah , just a thought you might wanna check your e-brake if its loose or not all the way down it might flash.
Old Jan 6, 2009 | 03:12 PM
Myst420's Avatar
I would start with checking the fluid. If it is getting low it could be triggering the sensor whenever you turn.
Old Jan 7, 2009 | 02:20 PM
dahonam's Avatar
SoCal Crew Member
If i remember correctly, it should be 3 or 4 beeps, mainly when making a right turn... Happened on my car and one of my customers cars, low on brake fluid. Fill it up a bit.
Old Jan 8, 2009 | 11:39 AM
It's the light that says "brake", not the DIC.
Old Jan 8, 2009 | 11:41 AM
Ok.....will do!
Old Aug 18, 2009 | 08:44 AM
E06-A4T's Avatar
I have almost the same issue, mine happens just about a minute into driving. Nothing to do with turning. Goes away then comes back little later. I guess I will have to check my brake fluid, and see if that may be the issue. I was going to make an appointment to have it serviced, but Ill give the fluid a check first. If it is that, wonder why its low.
