Is that a break issue?
Old May 28, 2012 | 08:26 AM
Tommy999's Avatar
Default Is that a break issue?
Hi:
I have a Audi A4 (2004 2.0 auto FSI petrol) about two years. Recently I found problems about break and acceleration and it get worse and worse.
Issue 1: When the car is standstill and I press and release the break pedal, the break icon in the gear selection panel will not light on immediately. It will light on about 3 or 5 second delay and then flash couple second and finally the light is on. The delay and flashing time is vary. Sometimes everything is ok, the icon will light on as soon as I release the pedal but sometime not. The break light sometime it will flash but most time it will light off when I release the break pedal. It looks like the break pedal or something else is "sticky". I am not very sure about it.
During the break icon is grey, if I press the break pedal, I can still change the gear.
There is no error or warning showing in the dash board at all. The break looks working during the car is moving.
Issue 2: There is another issue which I think it might cause by the break issue. Sometime when the car is moving, I press the acceleration pedal. The car does not accelerate even I push the pedal to the bottom. The rpm of engine isn't change as well so that there is no petrol pump to the engine. I have to release and re-push the pedal and then the car has reaction. Is this because the break is still "sticky" so that the computer refuse to accelerate?
These issue confuse and annoy me quite well and I think these are really risk of the car. I am not a mechanic so that I have to guess. Any ideas about the issues please? Thank you very much indeed.
BTW: Does these issues relate gearbox (hope not, otherwise...)? Does change the gearbox oil will help? Thanks again.
Old May 28, 2012 | 03:57 PM
johnnyquattro4's Avatar
I have had the issue with the acceleration as well. Now I can't drive more than 5 blocks without the brakes compressing until the car won't move at all....whether or not I touch the brake pedal. After resting for over an hour, the brakes finally release but will compress again if I try to drive it. Any ideas?
A6COB735G
Jul 31, 2015 07:57 PM
ebruce
Jan 19, 2011 09:27 PM
Clickyurdead
Jan 30, 2009 12:42 AM
ducracer21
Jun 20, 2007 03:30 PM
kujo
Jun 14, 2005 05:59 AM
