CEL and ESP on, need some advice
Old Aug 12, 2009 | 04:08 PM
Olezhka's Avatar
Default CEL and ESP on, need some advice
About 2 weeks ago the CEL and the ESP lights when on, but the car seemed to be running fine. so I ran the codes and then cleared them to see if the light comes back on.
the codes where:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16688 - Shareware Version. To Decode all DTCs
P0304 - 008 - Please Register/Activate - Intermittent
16689 - Shareware Version. To Decode all DTCs
P0305 - 008 - Please Register/Activate - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
17546 - Shareware Version. To Decode all DTCs
P1138 - 001 - Please Register/Activate
16486 - Shareware Version. To Decode all DTCs
P0102 - 002 - Please Register/Activate - Intermittent
After I did this the car started running horribly, It felt like it was missfiring and was about to stall every time I was in park. The CEL also came back on.
The next day the CEL went off and the car was running fine again, but right now about a week later the CEL and the ESP lights are on again.
I ran the codes again and now they are a bit different:
16685 - Shareware Version. To Decode all DTCs
P0301 - 008 - Please Register/Activate
16686 - Cylinder 2 Misfire Detected
P0302 - 008 - Implausible Signal
I need some advice on what to check and replace.
Old Aug 12, 2009 | 05:48 PM
Olezhka's Avatar
I just scanned for codes again
Here they are:
9 Faults Found:
P0301 - 008 - Please Register/Activate - Intermittent
P0302 - 002 - Lower Limit Exceeded - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 001 - Please Register/Activate - Intermittent
P1136 - 001 - Upper Limit Exceeded - Intermittent
P1138 - 001 - Please Register/Activate - Intermittent
Old Aug 12, 2009 | 06:03 PM
pa4ul's Avatar
coilpack
Old Aug 12, 2009 | 06:20 PM
Olezhka's Avatar
Originally Posted by pa4ul
coilpack
you mean the coils? all 6?
codes are showing misfire in cyl 1,2,3,4,5 but not 6
how can 5 go bad at the same time?
Old Aug 12, 2009 | 11:37 PM
Olezhka's Avatar
anyone else?
Old Aug 12, 2009 | 11:46 PM
rustlerboi1052's Avatar
What are you scanning the codes with? -Just curious.
Maybe your fuel is bad, if the CEL comes on and turns off frequently one of the injectors could maybe be clogged.
Reason I say this is because this just happened to me this week. Apparently there was bad fuel shipped into the US recently and it's been screwing people over. I just got some Lucas Injector cleaner and poured it into the tank.
Old Aug 12, 2009 | 11:52 PM
Olezhka's Avatar
I'm using the ebay cable to scan.
The CEL light is always on and so is the ESP, but I guess I can try the injector cleaner anyway. Who knows maybe it'll help?
I rather try the cheap stuff before I go and buy new coils.
thanks
Old Aug 13, 2009 | 06:46 AM
Dan1969's Avatar
https://www.audiforums.com/forum/sho...ighlight=P0301
Check this two out, I did a search on the Forum for P0301, useful tool, came back to this two threads, they both got the issue solved with the coilpacks and fuel injectors.
Old Aug 14, 2009 | 01:13 PM
Olezhka's Avatar
anything else I can check guys?
Old Aug 14, 2009 | 02:37 PM
audiprotein's Avatar
are you 3.0?
when your car is running lean it means that you car (ecu) is not getting enough of fuel/air...
could be a lot of things...
maf sensor is one of them
