CEL ON! HELP VAG-COM CODES Oxygen Sensors?
Old Jun 30, 2008 | 10:17 PM
tj19855's Avatar
Default CEL ON! HELP VAG-COM CODES Oxygen Sensors?
Monday,30,June,2008,20:46:21:27272
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
3 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 008 - Implausible Signal - MIL ON
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 008 - Implausible Signal - MIL ON
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent
Old Jul 1, 2008 | 02:43 AM
audiprotein's Avatar
Default RE: CEL ON! HELP VAG-COM CODES Oxygen Sensors?
Here is a bit similar thread https://www.audiforums.com/m_637248/mpage_1/key_/tm.htm
Looks like an air leak.
Old Jul 1, 2008 | 06:30 PM
tj19855's Avatar
When i start the car it idles very weird, like the engine wants to turn off but that is just on warm up. emissions suck. I will be replacing my temp sensor amd clear the codes and see if it works.
Old Jul 2, 2008 | 09:04 AM
yeah do it. Search Google for every code, you should be able to see what they mean.
ArcticZ
Feb 5, 2010 02:21 AM
tj19855
Jul 1, 2008 06:33 PM
brimhall99
Jun 22, 2008 03:03 PM
cabrioman1995
Jun 4, 2006 01:41 PM
gotaudi
May 16, 2006 02:58 AM
