Climate control replacement question
Old Jul 16, 2013 | 08:38 PM
jnevil579's Avatar
Default Climate control replacement question
Hey guys I have a 2003 a4 1.8
I had a short in the radio from a bad install job and it fried the Climate Control. I replaced it with a good used one. Seems to function great all the setting work fans , from floor to defrost all engage. Just no cold air. They put the coolant in it but still does not get cold in the cabin.
I was told by my local mechanic that the new climate control would have to be reset by a Audi Dealer. Is that true?
The fans blow but air is hot. Also lines just before firewall are freezing up.
Thanks for any Help its hot for a man in the south
Old Jul 17, 2013 | 05:31 PM
MKE_Audi's Avatar
I have heard the a new Climate Control board does need to be setup/programmed. Not sure if that is VagCom capable or if needs dealer.
If the pipes are cold its all working except the flaps and that is part of the programming for the new control.
Is it hot enough to go to the dealer yet and just get it done?
Old Jul 17, 2013 | 07:38 PM
jnevil579's Avatar
Hey MKE
Thanks for the response. I feel I will try my luck at a independent Audi specialist that is nearby before going to the Stealership lol
upallnight
Apr 25, 2010 12:33 AM
jbrx7tt
Nov 20, 2008 12:01 PM
96A4Owner
Sep 19, 2007 11:35 PM
juliet96744
Jun 17, 2007 09:35 AM
Kurlz11
Oct 7, 2006 11:11 AM
