Climate Control Question
Old Nov 18, 2008 | 08:15 AM
jbrx7tt's Avatar
Default Climate Control Question
I had a question regarding the temperature controls for my A3. In the past if I turned the heat up on my side it would also do the same for the pasenger side, for some reason it switched and now I have to set each one separately. Is there a setting to switch it so that I can just turn the drivers side up and they both go up? Not sure if anyone has encountered this, it is probably something simple but I cannot seem to figure it out.
Thanks in advance for any help!
Old Nov 18, 2008 | 11:41 AM
Speedster's Avatar
If you hold Auto button down while changing the driver side temperature switch the two sides will then track the driver side setting; it will stay this way until you change the passenger side setting which decouples the two.
Old Nov 18, 2008 | 12:41 PM
converted's Avatar
no need to change the temp, just push and hold the auto button until they sync.
Old Nov 20, 2008 | 12:01 PM
jbrx7tt's Avatar
Thanks!! I knew it had to be someting simple just didn't know what...
jnevil579
Jul 17, 2013 07:38 PM
gone postal
Jun 7, 2009 11:40 PM
96A4Owner
Sep 19, 2007 11:35 PM
juliet96744
Jun 17, 2007 09:35 AM
Giuseppe
Nov 27, 2004 01:01 PM
