Climate fault
Hi there,
My 03 plate 1.9 tdi has an issue with the climate system. It stopped working and when i checked it was low on gas. I regassed it but it still wouldnt work. It was stuck in ECON and i checked for fault codes and it led me to change the pressure sensor. This cleared the ECON light but the compressor still wont engage. I did a voltage check on the compressor plug and no volts present. The two fuses on the inside fuse box are ok and have 12v to them so im a bit stuck now as to why no voltage at the compressor?
Any ideas much appreciated.
Cheers
Cheers
