Code Blue!!!!!!
Old Jun 22, 2009 | 04:40 PM
dasBoost's Avatar
Default Code Blue!!!!!!
2002 A4 1.8T non-quatrro, CVT 99877mi
My car drove fine. then all of the sudden oil light comes on, and loud clicking comes from head. i assume no oil pressure due to no oil. i pull over and fill it full of oil. still.....hard clicking from cylinder head. no beuno. im kinda out of ideas. there is no oil on the belly pans, no oil on the ground where i park, tight oil pan nut. tight filter. no smoke or burning from exhaust. this is a very acute symptom. so it was fine one minute and not so fine the other minute. its sitting in a parking lot becuz i do not want to drive it due to risk of killing head or motor.
has any one every had this problom or know what it could be? or anything similar to this problom! please i need help!
my guess is the oil pump....
Old Jun 22, 2009 | 06:33 PM
shane.trammell's Avatar
how low was the oil? could be sludge
Old Jun 22, 2009 | 10:51 PM
dasBoost's Avatar
no oil on the dip stick.
empty basically. but idk where the hell the oil went.
Old Jun 22, 2009 | 11:55 PM
how long since the previous oil change?
Old Jun 23, 2009 | 01:29 AM
Rejoice's Avatar
So you put oil in but dipstick still comes up dry?
Old Jun 23, 2009 | 12:24 PM
dasBoost's Avatar
like 1000 miles. give or take. not long ago
yea. oil in crank case. no oil on dip......
my stupid car brain is telling me sludge....which is dumb. im gonna pull the pan and see what happens next.
Old Jun 26, 2009 | 09:33 AM
Dan1969's Avatar
Sounds to me like your oil pump went out.
Old Jun 26, 2009 | 12:35 PM
audiprotein's Avatar
In 90% cases, LOW OIL PRESSURE = SLUDGE
Dont drive your car until the full diagnose
Old Jun 27, 2009 | 06:00 PM
krystallbluea4's Avatar
if it works sometimes and then it doesn't it is most likely the oil pick-up sucking up some sludge which is temporarily held in place and then after the car is shut off it falls back down into the pan only to be sucked back up again. Dropping the pan on is a pain in the ***...good luck....
DarkPillow
Sep 12, 2010 09:14 PM
3dviz
Jul 12, 2010 06:17 PM
apaper
Feb 22, 2008 06:46 PM
iggy555
Aug 8, 2007 01:04 PM
