coolant flange replaced - still overheating?
Old Feb 27, 2010 | 10:20 AM
umaxjoe's Avatar
Default coolant flange replaced - still overheating?
i replaced the coolant flange of my 2003 A4 1.8T and it was a struggle. i made sure there was no air in the system and it is still overheating.
the car has never overheated before. i think it might be the thermostat not letting coolant through but i am not sure. does anyone know where i should start?
the upper hose is hot, and the lower hose is cold as ice. i dont get it.
please help
Old Feb 27, 2010 | 12:29 PM
shane.trammell's Avatar
thermostat
Old Mar 11, 2010 | 04:10 AM
DustDevilDennis's Avatar
Default Flange Replacement.
I own a 2003 A4 and it recently started overheating, took it to the dealership and they're saying it's the flange.
First of all, am I an idiot for taking this thing to the dealer? Anyone else recently had this problem? Typical cost for repair? I've read a couple things online and this problem almost seemed typical at 60,000-65,000 miles, which oddly enough is right where I'm at. Is this as common as I think?
Old Mar 11, 2010 | 07:18 PM
JoeD1346's Avatar
In my experience, the dealership has been the most knowledgeable place to take my car to, and when they have done work, they didn't break anything else. I recently replaced the flange on my car on my own, and it was a pita. If you are comfortable working on the car, it is doable, but there are a lot of parts you need to take off to get to it.
I would also have to say the thermostat. I recently had mine replaced, as well as the coolant fans (today as a matter of fact). I noticed over the past few days of driving before it was repaired, that when I pulled over and it overheated, there would be a lot of pressure in the coolant system, and the radiator would be bone cold. Replacing the thermostat is a fairly simple project as well.
Old Mar 11, 2010 | 07:26 PM
anthonyz's Avatar
I would try replacing the thermostat. Take the old one out and boil it in water on the stove and watch and see if it opens. This is a fairly easy part to check. If the thermostat opens cool it down and boil it again. Sometimes they stick closed and do not open. Good luck.
Anthonyz
Tony@zippyoil.com
judeman
Apr 7, 2012 04:46 PM
audinoob27
Mar 27, 2012 11:31 AM
2003 audi a4
Jan 17, 2009 06:39 AM
98 a4
Mar 13, 2008 05:55 PM
less_of_me
May 2, 2007 03:29 AM
