DIY front right signal bulb change!! help! Cant find existing post
2003 A4 front right signal bulb went out and can't find a way to change it there is an air intake/filter placed right on top of everything is there a thread on how to change it your self? i can't find any... if there is or if any of you guys know how to please help thanks much! tony |
RE: DIY front right signal bulb change!! help! Cant find existing post
remove the factory intake duct. Youll need a torx bit and remove the headlight...its pretty much self explanatory from there.
remove the headlight. 2 T25(i think that's right) torx bolts on top of the rad support. and then one down behind the light closer to the fender. you just have to loosen that one, and the light should slideright out
You can go to www.audidiy.com there is a thread on removing headlights on there, that's what I did and it explains every detail pretty well it's avery easy DIY.......
haha, or you can never go wrong with that site. always helpfull for sure
| All times are GMT -4. The time now is 08:49 AM. |
