DIY front right signal bulb change!! help! Cant find existing post
Old Mar 13, 2008 | 06:35 PM
tonylee's Avatar
Default DIY front right signal bulb change!! help! Cant find existing post
2003 A4
front right signal bulb went out and can't find a way to change it
there is an air intake/filter placed right on top of everything
is there a thread on how to change it your self? i can't find any...
if there is or if any of you guys know how to please help
thanks much!
tony
Old Mar 13, 2008 | 08:26 PM
n7plus1's Avatar
Default RE: DIY front right signal bulb change!! help! Cant find existing post
remove the factory intake duct. Youll need a torx bit and remove the headlight...its pretty much self explanatory from there.
Old Mar 13, 2008 | 09:57 PM
sean1.8t's Avatar
remove the headlight. 2 T25(i think that's right) torx bolts on top of the rad support. and then one down behind the light closer to the fender. you just have to loosen that one, and the light should slideright out
Old Mar 13, 2008 | 10:01 PM
jflores72's Avatar
You can go to www.audidiy.com there is a thread on removing headlights on there, that's what I did and it explains every detail pretty well it's avery easy DIY.......
Old Mar 13, 2008 | 10:02 PM
sean1.8t's Avatar
haha, or you can never go wrong with that site. always helpfull for sure
llove
Dec 3, 2012 09:22 PM
todd17
Nov 3, 2011 07:00 PM
pbrules10
Jul 5, 2010 08:24 PM
jhsoccerodp
Aug 9, 2008 01:32 PM
Mr BitJazz
Nov 13, 2006 05:56 PM
