Do you have to add oil every now and then?
hi all, about every 2000miles my min oil level light comes on and I add about half a quart of oil and it is fine after that and I change oil/filter every 3-4K miles.
What confuses me is that after adding half quart the dipstick shows ok oil level and I didn't think that half quart should triger a min oil level warning...
Is this normal or do I have to worry about something. Is there anything I should check?
I have 122K miles on the 1.8T and I am not driving it hard...
well, make sure you do not have a leak ( gasket? oil pan?)
its always helpful to start the car for a few seconds after you add oil, then turn off lets it sit a few seconds so the oil drains and check the level then.
good luck
good luck
If you are regularly checking your oil, and find a need to add it, you should. Not to keep it on the "high side" but to keep it in range.
If you find ourself doing that often, you might want to check why. From what you say, I'd really look into it. Honestly, with as much as you say you are using and having the light come on, I'd take it to a good mechanic or dealership.
What you can tell, MAYBE, on your own, without any skills, is... does it ever blow blue smoke when you get on it or start it up? (have someone follow you while you drive). That could be serious, expensive, like rings. Or, is it dripping when you are parked, that MIGHT be easy/cheap as a leaky gasket, or nasty as in a cracked something...
Some older cars just use a little, leak a little, have rings seep a little, and you just keep it topped off and leave it be. But that would be a 75 Chevy pickup or something you don't want to put money into. For a 2002 1.8T to need oil often, you need to get it fixed, you need to take it seriously.
Last edited by badlandz; 03-02-2009 at 03:49 AM. Reason: I spelled BLUE as BLEW.... Doh@!
that seems like you're adding more oil than should be needed. I know I have a small valve cover leak (have the gasket, but haven't had time to replace it) and when it comes time to change my oil, about 5,000 miles, I'm only about a half quart low.
even with syn the additives start to break down and don't really do what they are supposed to....... change that **** on the regular
well, 5,000 is the most I will go. I try to get it changed at 4k, but sometimes I stretch it to 5k. But I can't see that being TOO bad being that most people say change synthetic every 6k and audi says to change the oil every 10k (even though there is no way in he|| I would go that long without changing the oil)
