ECS Timing Belt kit with lightweight crank pulley.. Worth it?
Old Mar 17, 2009 | 10:11 AM
drewsph84's Avatar
Member
Default ECS Timing Belt kit with lightweight crank pulley.. Worth it?
Hey so I'm looking into ordering my timing belt kit due to the need to replace it all. I am looking at the ECS Tuning kits they have. I was wondering if there is noticable gains if you were to get the lightweight crank pulley they have in the higher kit? I have pretty much a stock 1.8tQ... Its about 120 bucks more so if its not very noticable I probably won't get it... Any advice?!...
Old Mar 18, 2009 | 06:03 PM
kwik_shift's Avatar
I would stay away from this. ECS R&D is no where near where I think it should be IMO. Think of the crankshaft as a balancing act. It is almost equal on both sides, the stock crank pulley and the flywheel...I assume would weight the same (if not, then the engine was designed around the weight difference). By subtracting weight from either end would throw off the balance of the crankshaft. Think of a see-saw. I would assume the lightened crank pulley would work best accompanied with a lightweight flywheel. However heavy flywheels are good for tiny engines like ours because without it they would simply stall out when put under heavy or repetitious loads (for instance, climbing a hill, burnouts, or even stop-and-go traffic). Simply for the power gains of the LW crank pulley, not worth it.
Old Mar 19, 2009 | 09:43 AM
drewsph84's Avatar
Member
Alright that makes sense. Thanks kwik shift! I just thought it would be an easy mod. I can't really afford other mods at the moment so I thought if I could sneak one in there why not! But that makes sense thanks!
Old Mar 20, 2009 | 07:16 PM
euro_2nr's Avatar
Right on bro. It may and may not help. But for the amount of power that you MAY gain outweighs the damage it may apply to your engine over a prolonged time. Save your money and get chipped OP. Only way you'll get the best bang for your buck
ECS Tuning
Apr 23, 2015 03:49 PM
ECS Tuning
Nov 8, 2013 03:47 PM
pbrules10
Nov 15, 2011 04:09 PM
Sick Boy
Oct 8, 2008 03:40 PM
mexicali225
Dec 22, 2007 02:31 PM
