AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   ECS Tuning Boost Gauge Install Issues... (https://www.audiforums.com/forum/b6-models-70/ecs-tuning-boost-gauge-install-issues-184819/)
Mick300ZX Jun 30, 2012 11:56 PM
Just finished installing the ECS tuning boost gauge vent kit.
Easy install... But, the gauge will stop working when the lights are ON. Lights OFF works perfectly. just emailed ECS tuning but not expecting an answer till Monday.
Anybody have an idea on what's wrong? Read around but no definite answer.
Thanks in advance.
olstyn Jul 1, 2012 12:30 AM
I take it there's a line to the light switch to sync it up with the dashboard backlight? (My Podi stepper motor gauge doesn't have that, but the setting that matches up best with the brightness level of the dash is invisible during the day, so it doesn't really matter.)
The only thing (other than a defective unit, of course) that occurs to me is that perhaps you've connected either the wrong line to the light switch, or to the wrong place on the light switch.
Mick300ZX Jul 1, 2012 08:59 AM
I would double check all connections later today, but I doubt it, the gauge lights up but kills it.
Mick300ZX Jul 1, 2012 05:05 PM
Just triple check all the connections, is all as per instructions.
Headlight switch harness Gauge power harness
Purple -----------------------------Red
Red--------------------------------Green
Blue/Grey--------------------------White
Brown-----------------------------Black
Lights OFF position it works, lights ON, it lights up but doesn't work...
ECS Tuning Jul 2, 2012 09:40 AM
Please send m a PM with an order number and I'll be happy to look into this for you.
Jason
Mick300ZX Jul 3, 2012 08:15 AM
Jason
PM sent... Thanks
ECS Tuning Jul 3, 2012 09:48 AM
Originally Posted by Mick300ZX (Post 1392263)
PM sent... Thanks
PM replied.
Jason
Mick300ZX Jul 25, 2012 09:24 PM
Problem Solved...
First of all, tahnks to Jason and all the guys at ECS tuning for taking the time to work with me on this.
Now... The issue was the power source in the headlight switch harness (purple wire) when the light is switched ON that source/cable will loose power. To fix it, just got power from another switched source in the fuse box.
Again, thanks to everyone that try to help me here and at ECS tuning.
ECS Tuning Jul 27, 2012 09:41 AM
Glad to hear everything worked out!
Cheers!
Jason
jeremy_brown_0 Apr 21, 2013 02:34 AM
Just have to say it's very impressive that the manufacturer is represented on here. I have plans on ordering an ECS Vent Boost Gauge (hence why I am searching the forums for it), and this gives me a great peace of mind. Good looking out Jason, and hopefully I can bypass any problems now =)
