ECU Link Error for OBD II
Old Mar 14, 2008 | 02:44 PM
auditurbo381's Avatar
Default ECU Link Error for OBD II
my car wont start... it cranks. but no firing
i know i need coilpacks. but i doubt that would keep it from even firing.
the car is a work in progress, but ran a few months ago?
it is missing a few check valves but it should fire! it did a few months ago. all i did was send in the ECU to get it chipped
now it wont link. there is no bent pins on the ecu or anything.
and i have sent it back in twice to be looked at.
oliver @ speedtuning says its fine
i tried to hook up my OBD and it says link error
it works on every other vehicle in my garage - Ranger, SLK, just not the A4. i dont get it?
any idea
Old Mar 14, 2008 | 03:01 PM
nihil's Avatar
Default RE: ECU Link Error for OBD II
Since you mentioned its a project car, is it possible that the car has been sitting for some time with a low/no charge on the battery? If so, maybe try disconnecting the computer for half an hour or so, then stick a freshly charged battery in there.
Old Mar 14, 2008 | 03:40 PM
it cranks.... it just turns over and over. no firing. it has been sitting...
but it cranks. but like its getting no fuel
Old Mar 14, 2008 | 04:07 PM
nihil's Avatar
Getting pressure at the fuel rail? Have you pulled codes yet? Disconnecting the computer should reset it.
Old Mar 14, 2008 | 04:19 PM
no codes. becasue it says link error? how do i check to see if my fuel rail has pressure?
and i have disconnected the computer mutiple times
Old Mar 14, 2008 | 04:24 PM
nihil's Avatar
There should be a schrader type valve somewhere on the rail. Cover it with a rag and push in on the center stem. The reason for the rag is that if there is fuel in the rail, and it is pressurized, it will squirt out. The rag should keep it from getting in your eyes, on your clothes, etc...
Old Mar 14, 2008 | 05:38 PM
ok i pushed that in an no fuel is coming out of the rail.... the air bleed type vavlve at the end right? i remember i checked this long ago and it squirted. nothing is coming out.
the car has gas.
it was ran low a while back
what the heck is wrong?
Old Mar 14, 2008 | 06:00 PM
nihil's Avatar
Well, lots of potential problems, from the fuel rail back theres possibility of clogged lines, bad fuel pump, bad switch/relay that turns the fuel pump on, bad computer that tells the switch/relay to engage the pump, or bad wiring to/from any of these components. But, since you mentioned the computer is not responding to a code reader that works with other vehicles, I'd start there. You might be able to yank it and take it to a dealer for testing.
Old Mar 14, 2008 | 06:02 PM
nihil's Avatar
Actually, since you said you sent it in for chipping, are you sure you're reinstalling it correctly? All the wiring in the right places and whatnot?
Old Mar 14, 2008 | 06:09 PM
its a simple disconnect.. reconnect. only two connections. and no bent pins on any of the connectors? and the fuel pump fuse is fine. but at least i have it isolated down to a fuel pump/ fuel issue right?
