Electrical problems???? No turn signals or high beams
Ok....The other day got into my 2002 Audi A4 1.8t to goto work. Welp...I have no turn signals....no cruise control...no high beams....no sunroof.....radio stays on unless manually turned off....no power windows....locks work...hazards work....also....ABS and ESP light stay on all the time now. Where do I even start as far as a repair goes? Sorry if Im a newb but...really need some help before I goto stealership. Thanks!:mad:
Nothing????
i would lean towards the ccm going out on you. ARe your carpets wet under the seat or near the pedals?>
The ccm in your car is under the steering wheel, you have to remove the panel under the wheel and it will be bolted flat in there, check if your Ecu seal is leaking, they usually leak right on top of ccm... I got one in the shop check it and if you need it I'll sell it to you.
I thought the CCM was under drivers seat on b6?? One headlight went out...now I have no headlights..WTF?? Any help is appreciated otherwise this Audi is getting replaced. I love the car but damn theirs more problems than worth at times. Thanks
are any other lights acting funny? It could also be your ecm located under the kick panel underneath the steering wheel.
No other light issues except for the ones mentioned. Appreciate the help guys...Im still stumped.
Anybody have any more ideas...car seems F#$cked.
im thinking its your electronic control module. . . Just a shot in the dark. But that module controls all the lights in the car. that one is located under the kick panel.
Originally Posted by alvy
(Post 1406845)
