Engine Code PO305
Old Mar 8, 2008 | 02:50 PM
fghtfire's Avatar
Default Engine Code PO305
My 02 A4 3.0 Quattro started shaking while driving, loss of power, sputtering and CEL blinking. I just had my car checked at Autozone and the code read PO305 Cylinder misfire detected-Cylinder number 5. I've been reading some other posts about the same conditions and was wondering if it is safe to replace the coil for my number 5 cylinder. Any ideas of thoughts??
Old Mar 8, 2008 | 04:20 PM
Audiphene's Avatar
Default RE: Engine Code PO305
Yeah....I had the same problem, but Cylinder 3. Mine was actually under warranty still so Audi did it, only took like 20 minutes. But it could also be the spark plug...but mine was the coil pack.
Old Mar 8, 2008 | 05:45 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: fghtfire
what i would do..... is take cyl 5 coil off, and switch it to cyl 1..... if the miss moves to cyl 1 then you know it is that coil..... if it stays at 5 then try moving the plug....... then if it stays i can't help...but if it moves when you move the plug it is that
xristos.greece
Aug 13, 2017 08:24 AM
Voypa
Oct 10, 2014 10:17 PM
motorwerks1
Dec 20, 2010 09:34 AM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
MilitantGrunt
Nov 1, 2006 09:16 AM
