engine light flashing, rough idle '02 A4
Old Jul 18, 2008 | 06:27 PM
tke1now's Avatar
Default engine light flashing, rough idle '02 A4
02 A4, 1.8T, running great yesterday.
On the way to work this AM, engine started skipping, and check engine light started flashing.
Rough idle at traffic lights.
Just turned over 80,000 on ODO.
My initial thoughts are change the plugs, and maybe coilpacks have gone bad.
I have VAG-COM it said misfires on cylinders 1 &3.
Didn't hear the turbo at all.
I'll start with plugs, but does anyone recognize these symptoms as a computer component failure?
Wanted to ask the group for help before I chase my tail for days.
Thanks in advance for your time and interest.
Old Jul 18, 2008 | 08:14 PM
audiprotein's Avatar
Default RE: engine light flashing, rough idle '02 A4
Coilpacks
Old Jul 18, 2008 | 08:30 PM
cali4life9092002's Avatar
definately! i had the same problem on my 02 and it was the coilpacks!!!!!
Old Jul 18, 2008 | 08:55 PM
RobGeorge's Avatar
yep def. sounds like the coil packs. Had to get new ones from the dealership. 30 dollars a pop. from what i read that if you had the older ones they might be covered under warantee by the dealership because of a recall on them. But might want to check it out if you dont want to dish out 30 for one. mine was at 102k when mine went...
Old Jul 19, 2008 | 10:51 AM
02tq's Avatar
I keep two coil packs in my trunk I've blown through 5 in 4 years
Old Jul 19, 2008 | 05:20 PM
tke1now's Avatar
Guys -
Went to replace coilpacks, found spark plugs covered in oil.
Oil had somehow pooled around the plugs, one wasn't even visible.
So I changed all plugs and coil packs.
Got a great big cloud on the first start after removing spark plugs, oil leaked into ignition chambers I guess.
Have any of you ever had an issue with oil collecting around plugs?
What causes it, how does it happen?
Old Jul 19, 2008 | 09:51 PM
hardenthefckup's Avatar
tighten the spark plugs down really good
Old Jul 20, 2008 | 03:18 AM
PDX04a4's Avatar
Default do not tighten plugs too much
uhhh, do NOT tighten the spark plugs really tight. basically you want to tighten them a little more than fully. if they are tightened too much you can cross thread them easily, then you are fucked.
Old Jan 27, 2009 | 08:29 PM
jhsteel82's Avatar
yeah don't overtighten them cuz then you are screwed big time. Sometimes the oil in the plug chambers is caused by the valve cover gasket needing to be replaced. There is a good diy forum out there for this that I have seen.
Old Jan 28, 2009 | 07:29 PM
nexusgroove's Avatar
Talking
Coil Pack!! since I have did the APR stage I, I have been going thought these coils every 7 months.
