ESP Problem light 2004 A4 1.8T Cab
Old Aug 19, 2009 | 04:24 AM
sammy shamal's Avatar
Exclamation ESP Problem light 2004 A4 1.8T Cab
Hi There.
2004 A4 1.8T Cabriolet.
I recently had my front left headlight replaced. Technician struggled and had to remove various parts to get to the light housing.
Since this I have had ESP light come on on my dashboard once I've driven the car on a motorway for over 15 mins.
The car runs fine at all times and the ESP light resets itself if I stop and restart the engine.
Car had major service 6 weeks ago at 54,000 miles
Does anybody know if this will be linked to having the front left headlight replaced?
Where is the ESP control box situated in the engine bay?
Thanks for your thoughts
Old Aug 21, 2009 | 01:14 PM
docurley's Avatar
Whe the esp light come on it can be caused by a bad brake switch which are quite cheap and easy to fit just need to remove the lower dash on the driver side to get to the brake switch.
Old Aug 21, 2009 | 11:10 PM
Dan1969's Avatar
Maybe the tech forgot to connect something, or blew a fuse when he was "struggling"... anyways try not to take your audi to those quicky places, have a trusted mechanic or an Audi Tech or yourself do the work if you're confident.
Old Sep 1, 2009 | 07:12 PM
Looks like it was a loose connection behind the front left light.
Took it back to Nationwide Autocentre who fitted the bulb, He played with the connections and said that one wasn't fully in.
That was two weeks ago and not had a problem since.
Thanks for the advice!
luciddream42186
Jan 25, 2012 08:13 PM
muurai
Dec 22, 2010 11:53 AM
GRRTX7
Mar 22, 2010 11:11 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
RonA4
Sep 19, 2005 06:14 PM
