ESP switch peels... how to replace it?
Old Oct 15, 2009 | 02:32 PM
kchao2000's Avatar
Default ESP switch peels... how to replace it?
I think it is a common issue to Audi, interior paint for switches/bottons peeling. I never touched the ESP button before and it just started peel. ECS sells replacement for it. Anyone know how to replace it?
Thanks.
Old Jun 8, 2011 | 10:40 AM
chaka33's Avatar
Default Solution?
I have the same issue. I've found a replacement switch for about $25, but I'm not sure if this can be swapped out without removing parts of the dash. Any ideas?
Old Jun 8, 2011 | 12:06 PM
pa4ul's Avatar
radio has to be removed and the cartray and esp button come out together. Then u can take the button out once its pulled out
Old Jun 8, 2011 | 02:41 PM
TheycallmeClutch's Avatar
If the ESP switch fading is your biggest problem with your Audi then let's trade lol...
Old Jun 12, 2011 | 07:23 PM
ilackav8's Avatar
i replaced mine last summer. you dont have to pull the radio out or dash apart,there are clips on the top and bottom of the button.
if you have a replacement switch, take a peak at their position (or google image search for one, lots of pics). all you need is a really skinny flat head to get in there and depress the top clip, and pull forward carefully. just be careful to not chew up the dash above it.
Old Jun 16, 2011 | 04:06 PM
chaka33's Avatar
Default Mission accomplished
Thanks guys. I was able to swap it out pretty easily.
I decided to remove the top trim piece first. I used a paint can opener to "hook" the back of the trim and pulled forward. If you open up the glove box, you get get a hold of it.
Once the trim piece was off, I used a small screwdriver to press down the silver clip like ilackav8 mentioned. Little damange done to the button I'm replacing, but none done to the trim or dash. Here's a pic for those yet to replace it.
Old Jun 17, 2011 | 12:46 AM
BesI's Avatar
Some ppl dont know what to do with all the money they got,as i see audis dont joke when something is start breaking you better stay on top and not woried about the switch .
Old Dec 11, 2012 | 07:10 AM
JeremyCasilli's Avatar
Default Trim Removal
Hey Chaka - Did the trim piece just pop off when you used the paint can opener? Or is there screws that need to be removed as well?
Old Dec 11, 2012 | 11:17 AM
chaka33's Avatar
No screws. The trim is just held on by some clips. It took quite a bit of force to pop the first clip off, then the rest were a bit easier. Start near the glove compartment.
Kryptonic
Oct 30, 2010 03:22 PM
gone postal
Sep 16, 2009 11:57 PM
alan93
Feb 5, 2007 10:59 PM
bmwtoaudi
Nov 19, 2006 04:02 AM
