fault codes.
2002, v6, petrol, a4 cabriolet.
Hi, my engine managment light has couple of times and wanted to know how to solve the problems that have shown up on the scan i did. I have read threads on the forum about the clutch pedal problem but needed advise on the others please. 5 Faults Found: 17947 - Clutch Pedal Switch (F36) P1539 - 004 - Implausible Signal 17831 - Secondary Air Injection System; Bank 1 P1423 - 002 - Insufficient Flow - MIL ON 17819 - Secondary Air Injection System; Bank 2 P1411 - 002 - Insufficient Flow - MIL ON 18010 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent 16890 - Idle Control System P0506 - 002 - RPM Lower than Expected - Intermittent When i disconect the battery to reset and scan again none of the above show up but a different one. 1 Fault Found: 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent Any help would be great. Thanks. |
First off disconnecting the battery does not fix any problem the car has. It just makes the check engine light go out until the car runs the monitors again & discovers the problem again.
What are the complaints that you are trying to resolve? From what i see you have a problem with the secondary air injection system that will make the check engine light go on , other than that do not look for problem unless you have a complaint! |
seems like you have a vacuum leak on the control side of secondary air system
Thanks for that, all i need to know.
