Fault Codes P0741, P0302, P0303, P0031, P0300, P0013, P0021, P0421, P0431
Old Mar 14, 2008 | 12:39 AM
damselndistress's Avatar
Default Fault Codes P0741, P0302, P0303, P0031, P0300, P0013, P0021, P0421, P0431
Sorry (dupicate post)Newbie. I just read the thread abt CEL's and was advised to post the codes in the subject. Thnx
All,
Happy Thursday!
Help!
I'm experiencing the following with my 2002 Audi A4 3.0 82000 miles:
*Check engine light ON- flashes (stays still @ times)
*Hood light- blinks as though the hood is not closed; however it is. (I think this is a broken sensor?)
*Service Light ON- abt a week now
I'm taking the Audi to the dealership 1st thing in the morning. Irequested a service which I was quoted $450 and the service manager suggestedto get a timing belt joband oil changeinstead.....ONLY $1900. The service manager advised that he has seen too many times were the timing belt breaks before the ownermanuals suggested replace.He also suggested that I get a service @ 90,000 instead. He wants to do prevented maintenance I guess?Also I took myAudi to Auto Zonetoday andmycheck engine codes read as follows:
P0741, P0302, P0303, P0301, P0300, P0015, P0021, P0421 & P0431.Will someone pleaseexplain what this means to me? Are these costly repairs.Could a GOODmechanic easily work on Audi's are should I always have Audi certified technicians under the hood (dealership)?
Thanks in Advance,
damselndistress
Old Mar 14, 2008 | 04:17 AM
techbod's Avatar
Default RE: Fault Codes P0741, P0302, P0303, P0031, P0300, P0013, P0021, P0421, P0431
P0741 - Powertrain: Torque Converter Clutch Circuit Performance/Stuck Off.
a P0013 code trigger the check engine light? This code will trigger the check engine light under the following condition:
The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) circuit to the computer for high and low voltages. If the voltage falls below a set limit for a specific amount of time during this test, the check engine light will coPossiblePossible Causes:
Open or short in the VCT circuit
Open in the Vehicle Power circuit
Open or short in the VCT solenoid valve itself
Damaged computer (PCM)me on and set this trouble code.
http://forums.audiworld.com/s4b6/msgs/426643.phtml
A code P0421 may mean that one or more of the following has happened: [ul][*]The catalytic converter is no longer functioning properly[*]An oxygen sensor is not reading (functioning) prosparkplug[*]A sparkplug is fouled up.[/ul]
e following has happened: [ul][*]The catalytic converter is no longer functioning properly[*]An oxygen sensor is not reading (functioning) properly[*]There is an exhaust leak.[/ul]
Diagnostic trouble code p0031 ho2s heater control circuit low bank 1 sensor 1.
p0300/2/3 are spark plug/coil related and all sounds like P0013 could be the cause of all the other codes which means the other things are probably ok and are codes stored because ok P0013.
to find answers on dault codes simply type it in your google search engine
Old Mar 14, 2008 | 07:47 AM
Thanks for the explanation and codes resource!
Old Mar 14, 2008 | 10:22 AM
techbod's Avatar
no problem ( the more codes means that one thing is causing the problem ) in this case I would put it down to cam timing as this would cause all the other issues, cam sensor/knock sensor just a quick guess
Old Mar 18, 2008 | 11:39 AM
Thanks Again!
Update........
Audi Loaner Car.......No Charge!
L/F Turn Signal Bulb & Holder & Taillight Bulb......$31.69
Oil & Filter Change.......$61.60
Dignostic........$114.00
Hood Lock (sensor).......$259.59
Timing Belt ............$1900.00 (recommended)
Both Catalytic Converters.........$2849.64
***Over the miles for warranty replacement of converters!
Getting a less expensive car..............PRICELESS
Old Mar 22, 2008 | 12:27 PM
GL8386's Avatar
OUCH..But now that thing should drive for you! ha GL
Old Mar 23, 2008 | 02:09 AM
veloracer's Avatar
That sucks to have to pay for new cats. For those who don't know, the federal emissions warranty is up to 80k. This covers the whole emissions system and the ECU. At least your car is back up and running w/o any problems.
Old Mar 25, 2008 | 03:18 PM
3.0AmuletA4's Avatar
ORIGINAL: veloracer
Would that mean if my cats on my 2003 3.0 went... (i have 48K miles) it would have to be covered by Audi?
existence1000
Apr 8, 2013 12:47 AM
chongboi
Apr 26, 2010 07:09 PM
CALI KID
Sep 23, 2008 03:20 PM
monkey323i
Apr 28, 2008 11:05 PM
