flash/ecu
Old Mar 27, 2008 | 02:43 AM
A13ART's Avatar
Default flash/ecu
aright i have a 05 1.8t still under warenty for the next 45k miles and i was thinking of getting flash/ecu how does that effect the wrenty and what is better the apr or giac one
Old Mar 27, 2008 | 08:23 PM
auditech79's Avatar
Default RE: flash/ecu
It will eliminate the warranty, but no one will give a crap if its chipped un-less you blow the engine or something. Then they will actually check for a chip.
As for the chips, APR is better if you like smooth engagement
GIAC is a little bit more torquey.
Old Mar 27, 2008 | 08:29 PM
amiller86's Avatar
If you're really concerned with it, get the APR with the stock program. You can switch the ECU from tuned to stock with the cruise control. Thats whatI do when I have to bring my car to the dealer. Alot of people will tell you it's a waste of money though... (kinda agree, even though I use it)
Old Mar 27, 2008 | 08:58 PM
ultrasport's Avatar
I have apr 93 and stock programs and i use it all the time. When its real cold or real hot or long road trips I turn the chip off. Not really sure if it really makes a big deal but gives me some piece of mind on turbo and engine longevity. My 2 cents
Old Mar 27, 2008 | 09:55 PM
A13ART's Avatar
mine i auto matic does that make a difrence in the gearing like you said wont they notice the fuel lines need and the D.V
Old Mar 27, 2008 | 10:52 PM
amiller86's Avatar
ORIGINAL: A13ART
Umm, I don't understand that statement. If your asking about your transmission, the chip will be perfectly fine. Automatic transmissions have some issues when you start to make alot of torque, but shouldn't be an issue here. As for fuel lines, there is no need to run new fuel lines. You can get a +1 which incorporates larger injectors, but thats not something they would notice. The stockdiverter valve will eventually wear out, so many if not all opt to replace it. It's never been an issue for me at the dealer, and mine is polished silver (anyone can see it when they open the hood.)
I_B_Audi_S4_B6
Dec 2, 2011 12:35 PM
dkim
Nov 28, 2007 10:05 PM
Indiepunk
Aug 23, 2007 02:06 PM
ahgood
Jan 7, 2006 06:29 PM
