AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   flashing coolant light on dash (https://www.audiforums.com/forum/b6-models-70/flashing-coolant-light-dash-143586/)
tatsmyaudi_a4 Dec 30, 2009 02:52 AM
hi everyone, just recent my 03 a4 1.8t waterpump went out on me. i got the car towed home and did the diy water pump/timing belt change. after i got done and everything works. but when i took the car around the block to make sure it doesnt over heat i notice the coolant light flashes on the cluster. coolant is at the max on the coolant tank.
could it be the coolant temp sensor?? i dont have any check engine codes.
Midniteoyl Dec 30, 2009 03:20 AM
Make sure you have all the air out. Usually takes a few tries and heat/cool cylces to purge all the air... Is this the 'coolant temp' or 'coolant level' light?
Dan1969 Dec 30, 2009 11:55 AM
There's most likely air in the system, make sure is completely purged out.
tatsmyaudi_a4 Jan 1, 2010 12:24 AM
yupe just like everyone said. the sensor under the coolant bottle was unplugged. thanks everyone and have a happy n safe new years
