flashing sign on dash - turbo?
Old Oct 13, 2009 | 11:09 AM
viviyer22's Avatar
Default flashing sign on dash - turbo?
Hello there,
Here's my issue, last week while I was driving my 2004 Audi A4 1.8T Quattro, a “red can” kinda symbol appeared on my dash, this is the same sign that’s on the turbo if I open my hood. I have attached a pic for your reference.
The sign hasn’t appeared for the past 2 weeks though, however just to be on the safe side, I would like to know what the issue is/was. Also last month the car ran out of oil for the 1st time ever. I had replaced the oil just a month ago.
I would be grateful if anybody could give me some insight into any potential probs here. Please email me at lordiyer@hotmail.com.
Thanks
Vivek
Old Oct 13, 2009 | 11:54 AM
shane.trammell's Avatar
thats an oil can, your oil is probably low again.
Old Oct 13, 2009 | 12:04 PM
monsterrider's Avatar
It indicates low oil pressure. You are either burning or leaking a lot of oil. It will come back on when the level is low again, typically going around a curve and the oil moves away from the pick up.
Old Oct 13, 2009 | 12:08 PM
pa4ul's Avatar
if its yellow u need to change and if its red u really need to change!
Old Oct 13, 2009 | 12:45 PM
viviyer22's Avatar
Default thanks
[QUOTE=monsterrider;1138785]It indicates low oil pressure. You are either burning or leaking a lot of oil. It will come back on when the level is low again, typically going around a curve and the oil moves away from the pick up.
[/Thanks, do i have to take it to a mechanic or can i just buy some synthetic oil and top it off myself? Any special requirements as I pour the oil?]
Old Oct 13, 2009 | 01:03 PM
viviyer22's Avatar
Default one last question
Thanks
Vivek
No special requirements, just use a good synthetic oil. Check the oil level regularly for a while to see what's happening. If it continues to disappear you have a major problem that needs a mechanic.
The low oil pressure light is red indicating you have a serious problem - no oil getting to the engine parts. Driving the car with the light on will cause permanent major damage, that's why you need to stop immediately if the light comes on.
Old Oct 15, 2009 | 10:54 AM
viviyer22's Avatar
Default oil level is good...no leakage either
hello Bob,
Got my oil checked...the level was good..checked for leakage too...no leakage and no burn...maybe it just had to do with me going round the curve or something....is there anything else i must get checked?..or can i just assume that was a randomly generated error message on my dash,..that just flashed and then disappeared..car seems to run very normally
Thanks
Vivek
Old Oct 15, 2009 | 12:55 PM
Best thing now is just to watch it and check the level once a week or so. If the oil level stays constant over time, you're OK.
Bob
Old Oct 15, 2009 | 04:31 PM
You need to have your pressure checked. It could be related to sludge and you don't want to drive it if that's the case.
