Fuse Panel Location
Old Mar 29, 2008 | 10:01 AM
A4Boost's Avatar
Default Fuse Panel Location
Hello again everyone.... I know that this is a super newb question but my winshield washer pump has stopped working and before I replaced the pump I wanted to check the easiest thing first, the fuse. For the life of me I cant find the fuse panel anywhere[]Can anyone help me on the location ofthe panel?I had read on the forums that fuse #37 was the fuse that would cover the pump, can anyone verify this? I have an '03 1.8T Q 5-Speed A4 Thanks in advance for any help.
Old Mar 29, 2008 | 01:17 PM
rccks96's Avatar
Default RE: Fuse Panel Location
It's the side panel on the drivers side, to the left of the steering wheel (it's covered up when the door is closed.
I believe you need to replace the fuse with a 30 amp (even though the manual says 20 or 25 amp).
This happened to me about a month ago. Good luck.
Old Mar 29, 2008 | 04:43 PM
A4Boost's Avatar
Thanks alot!I found the panel and putthe new fuse in and everything is good to go. I can't believe that my headlight washers are strong enough to spray my winshield! Thanks again for the help.
muffinman
Aug 12, 2010 02:24 AM
velvet jones
Jul 2, 2010 05:09 PM
xster
Dec 17, 2008 02:02 AM
shawten
May 5, 2008 01:45 PM
nyguy
May 9, 2005 11:16 PM
