HELP!!! 19x8 - 42mm offset ... on A4 B6??
Old Feb 11, 2009 | 11:21 AM
SouthernAudi's Avatar
Default HELP!!! 19x8 - 42mm offset ... on A4 B6??
how well would a set of 19x8s with a 42mm offset fit on my 2002 Audi A4 (FWD)? need 7mm-8mm spacers? specific tire size I should use?
I do plan on lowering it some ... but not much.
Old Feb 12, 2009 | 11:09 AM
VitaminB6's Avatar
Use this wheel offset calculator to calculate the difference in inner and outer clearance from your stock wheels: http://www.1010tires.com/WheelOffsetCalculator.asp
I run 8.5 with 38MM offset with no problems and clearance to spare. Compared to these, by my calculations your wheels will fit just fine (2 MM less inner clearance, 10 MM more outer clearance).
Old Feb 12, 2009 | 11:31 AM
vdubstreets's Avatar
Stock wheels are 17x7.5 et 45, so your .5 wider and only 3mm out. You will be fine you may want to space a bit but thats upt to you.
Old Feb 13, 2009 | 01:38 PM
you guys are great ... thanks!
IseeSlowPeople
Aug 23, 2010 12:04 PM
pbc_18
May 5, 2009 06:19 PM
01AudiA4
Oct 31, 2007 06:37 PM
Driver500
Oct 2, 2006 01:24 AM
nonoA4
Jul 26, 2006 04:09 PM
