Help.....Brakes...
Old Jun 10, 2013 | 04:51 AM
dazypace's Avatar
Default Help.....Brakes...
Hi, now i'm not a expert with cars so your help will be much appreciated, my brother in-law has recently repalced the front pads on my 1.9 TDI sport, 54 plate but after 2 weeks and as I press the brake peddle there is a sharp knock/tick although somthing is sticking/releasing, now this only happenes when the brakes have warmed up?
This has been going on for around a month now so I gave him the car back to have a look, he striped the breaks down and put them back on only to find the same problem, he's not a mechanic so is left scatching his head.
Any idea's before I put it in the garage to see if they can find a fault?
Regards
Daz.
Old Jun 10, 2013 | 11:02 AM
EastTNPharmD's Avatar
I would double check all the springs and clips, also the pins that the caliber slides on need to be well lubricated. Had this issue with my superduty. Not sure if this helps with your tdi as I have not taken one apart but just good things to look for.
Old Jun 11, 2013 | 01:24 AM
dazypace's Avatar
OK thanks, I will give that a go and see what the out come is.
Old Jun 11, 2013 | 02:02 AM
kikin's Avatar
Default check and lubricate the caliper bolts
thats maybe helps
Old Jun 11, 2013 | 06:14 PM
pa4ul's Avatar
that small spring clip that holds the pads. If that is not 100% in u will get that clank. Try squirtting some wd40 on it.
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
