HID LIGHTS help!!
Old Jul 16, 2011 | 12:46 PM
00a4ko4's Avatar
Originally Posted by pa4ul
here is my 8000k setup
Hey did you get your kit from ddm? and is it 35w or 55w?
Old Jul 18, 2011 | 01:00 PM
James94's Avatar
Yeah he did get it from ddm. and there 35 watt. He didnt want to get the 55 watt because there was a possibility of a fire im guessing.
Old Jul 19, 2011 | 11:19 AM
pa4ul's Avatar
James is correct. 35 all the way around. heard of some people having the fog lights melting the housing with 55watt so i figured i woudl rather not risk it. But u can put 55watt in the lowbeams but keep in mind that a 55 watt glows brighter so if u get a 55watt 6000k and a 35 watt 6000k they will be a bit off in the shade of blue.
Old Jul 19, 2011 | 11:56 AM
JohnnyMoseley's Avatar
do you get any error codes? im thinking about doing this with both 8k real soon... definately looks good man
Old Jul 19, 2011 | 02:30 PM
James94's Avatar
if you order from ddmtuning.com don't expect them to ship it right away. its been a week and they JUST shipped my item because its "ground" shipping
Old Jul 19, 2011 | 06:22 PM
pa4ul's Avatar
no error codes unless. . . . u mount the ballast to close to the abs module. On the passeneger side i believe. ddm is usually pretty quick about shipping. Wonder why it took so long for them to send it out. Usually takes 3 days to get to my house once its shipped though.
Old Aug 1, 2011 | 06:58 PM
subtlemastermind's Avatar
Just for reference, keep in mind that those that come with factory HID headlights have a different bulb sizes:
Regular halogen bulbs (H7 low-beam):
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Factory HIDs (HID-D1S low-beam):
Hopefully someone can verify this: my high-beam bulbs are H10 bulbs. When I was upgrading my factory (4300K) HID headlights with (6000K) HID headlights, I noticed that. According to the replacement guide (above), they are to be H7 on both (those with, and those without factory HID headlights). My fog lights are still size H11, and everything else is normal though. Has anyone else discovered that? Just curious...
Old Aug 2, 2011 | 12:01 PM
  #18
pa4ul's Avatar
high and low beams on halogen Capsule are both h7. Certian modles s4 iirc have both high beams and low beams built in together. Bi-xenon. others carry a ds1 hid bulb for low beam and high beam i believe stays h7.
Old Aug 3, 2011 | 08:50 AM
  #19
While that may be true, I know that personally, on my car, even on the headlight housing it is indicated that my low-beam bulb is an HID-D1S and my high-beam is an H10. Otherwise, I would just assume that when the previous owner installed the headlights they had used the wrong size. The high-beam bulb was even made by Sylvania (ironically enough). Perhaps it is only my car that is different...but yeah, like I said, it's even indicated on the label attached to the headlight housing; strange...
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
