hid teaser
Old Jan 29, 2009 | 01:31 PM
pa4ul's Avatar
Default hid teaser
Ohh i got my hid kit in postin up pics later today and got the led license plate lights.
Old Jan 29, 2009 | 09:37 PM
pa4ul's Avatar
Plate LEds
Old Jan 30, 2009 | 12:23 AM
scskim's Avatar
nice work. they make a big difference at night dont they
Old Jan 30, 2009 | 11:42 AM
pa4ul's Avatar
helll ya
Old Jan 30, 2009 | 01:23 PM
krystallbluea4's Avatar
Good work. Night vision is much improved. I did highs/lows and fogs all @6k. The fogs I wished I would have stepped down a level to the 5k range because the fog-light housing makes them render a slightly ultral-violet tone more so than the highs or lows. I tried to correct for it by chorme plating the inside of the housing and it did increase the brightness to a literally ridiculous level however the uv tone is still slightly pronounced.
The Highs I love because I never use highs to pass (still can they fire right away and are at full potential in seconds) and I've spliced and indy vag'd my fogs so when highs are on I have highs lows and fogs illuminating the way. Bright is an understatement. It's fckin high-noon.
BTW, When first did mine I had condensation build up over a very humid night, so I coated the rubber grommet that you place through the access cover on the headlight assembly with some rubberized sealer and have not had any condensation in the headlamps since.
Old Jan 30, 2009 | 02:08 PM
pa4ul's Avatar
yea i silconed it up when i first installed it. I have silverstar bulbs for my high beams and there are freakin bright bright. A bud of mine has a acura tls with bixeon and my silverstars are bright then his highbeams. how hard was the install on the fogs? and where did u mount the ballast for the fogs?
Old Jan 30, 2009 | 03:42 PM
Fogs are easier than the headlights. Torx bit and some patience. I mounted my ballasts with 3m double sided adhesive to the inside of my fenders.
The HID's in the high beams are usually avoided because on most cars with seperate lamps for Highs and Lows the low-beam is turned-off when the highbeam is turned on. The second or two that it takes the HID to heat up when its initially energized could be dangerous at night when you switch to the high-beams (once they've been heated I can flash just fine). Our cars do not disengage the low beams when the highs come on so that was irrelevant to me.
I thought about getting the silverstar's myself until I discovered they have a very short life. On top of that the silverstars simply increase the color of the light(higher on the kelvin K scale). The silverstars being a halogen lamp, limited by their design, still provide the same lumens (light output) as your standard halogen. Lumens is actual light output not color. HID's by design (electrical arcing and gas) put out 3 times the lumens of a halogen (electrical current through a filament) regardless of color scale rating.
Old Jan 30, 2009 | 09:15 PM
pa4ul's Avatar
woaah now chris sum big words there. i had purchased my silverstars when i bought my car about 2 half years ago. They still fire up like a champ. when i had them in my projectors they gave off a real light blue on cutoff but nothing compared to the hid. i just want the fogs done soon cuz no car in my city has them so it will be like wtf. But send me those pics when uget a chance no hurries here.
Old Jan 30, 2009 | 11:58 PM
Sawree bout all dem werds boss sumtimes i jus kant spress wut i wantz ta say wif out dem.
Where I mounted the ballasts for the fogs (each side):
https://www.audiforums.com/forum/alb...pictureid=3320
HID High/Low/Fog:
https://www.audiforums.com/forum/alb...pictureid=3321
HID Low/Fog:
https://www.audiforums.com/forum/alb...pictureid=3323
HID Fog/g-dam DRL's:
https://www.audiforums.com/forum/alb...pictureid=3322
Old Feb 1, 2009 | 04:39 PM
pa4ul's Avatar
lol now that my language chris. Damn man ur fogs give that purple hue. How u get the fogs going without the headlights on did vag it or u splice the wires behind the switch?
NickBroderick
Apr 11, 2010 01:06 AM
bradtyler02
Feb 25, 2010 07:35 AM
FASTER
Jul 20, 2008 01:29 AM
