How to disassemble sunroof panel?
Old May 7, 2010 | 07:19 PM
Sardor's Avatar
Default How to disassemble sunroof panel?
I am having a problem with sunroof closing by itself sometimes. Found out that the contact strips might need some cleaning. I have tried to take the panel out for more then an hour and no success. Can anyone explain me how it's done? If there is some tutorial with pictures that would be even better!
Old May 31, 2010 | 08:31 PM
setoff's Avatar
I have the same issue with 03 A4 Quattro when you do find out please let me know
Old May 31, 2010 | 09:31 PM
dukesean's Avatar
Old Sep 7, 2010 | 05:55 PM
Sardor's Avatar
It was actually a fairly easy fix, I took the panal apart and there were two metal peaces which touch another metal peaces ( dont know the names of it) to open and close your sunroof. They felt like they needed to be pushed out a bit, so a simple spoon helped me in "unpushing" them. After I put the panel back together, it works fine now, no more ghosts in my sunroof.
Old Sep 19, 2010 | 12:44 AM
Princess G's Avatar
Quick question....was your sunroof light working or not. I couldnt get mine to work earlier. The light wasnt working around it and the sunroof had no power. After i manually closed it, i turned the switch to the close position and i heard it making this loud crazy noise. Any input would be great . Thank you
Old Sep 19, 2010 | 10:37 PM
Sardor's Avatar
Yes, everything on mine was working, only thing that was disturbing me was that it closed by itself sometimes. I'm not familiar with your problem unfortunately, but noise usually is not good.
dmantis
Aug 24, 2015 11:22 AM
Prizmatik
Feb 27, 2012 03:32 PM
DownriverAudiGirl
Aug 8, 2011 07:51 PM
bettysdad
Jun 19, 2010 09:47 PM
tariqahmad
Oct 16, 2009 11:49 AM
