Ignition Coils
Old Nov 26, 2008 | 04:30 PM
A4Sooner's Avatar
Default Ignition Coils
what are the symtoms when needing to replace ignition coils?
Old Nov 26, 2008 | 05:15 PM
audiprotein's Avatar
Usually you car start misfirig crazy... flashing cel for about a min and then a solid cel.
Old Nov 27, 2008 | 12:56 AM
zwickau's Avatar
Just runs rough, loses power, but can still drive. When it happens take it in and get all 4 done. Its very obvious when one goes. 03-04 1.8T are the most common having the issue (supplier got their hand slapped for this one)
Old Nov 27, 2008 | 12:01 PM
02A4Turbo's Avatar
From personal experience, when its minor the car will randomly lose some pep cuz the rpms would drop a bit under heavy accel or at stoplights the rpms would bounce between 500 and 800.. when it got much worse my entire car would jerk whether im at a stoplight or accelerating at any rate
Old Dec 2, 2008 | 08:36 PM
indy089's Avatar
hey, i recently had to have my ignition coil replaced. The car had a really odd vibration to it, specifically in the shifter. and the acceleration was slightly slower.
I brought it to Audi and it was about 180$ fix
Old Dec 3, 2008 | 10:30 PM
bloke's Avatar
how many coils did you get replaced? If it was just one, seems like a rip off on the labor itself. You should just buy new ones and keep them in your car because it takes like 2 minutes to do.
Old Dec 4, 2008 | 03:04 PM
A4Sooner's Avatar
went ahead and had them all replaced.
it was recommended.
Old Dec 4, 2008 | 07:15 PM
bloke's Avatar
were you told how many and what cylinders? Its a nice piece of information so when the next time it happens, you can just switch it out yourself instead of trouble shooting
Old Dec 4, 2008 | 07:59 PM
Agent1.8's Avatar
I happen to work for an autoparts store, I sell about 20 of these coils a week, I also keep 4 in my trunk incase of emergency (recommended from this forum). They are relatively inexpensive and can be replaced in a few minutes.
Old Dec 23, 2008 | 11:46 AM
ckbkny's Avatar
My old Jetta had one ignition coil pack for all 4 cylinders. It went like clockwork but was easy to replace yourself and dirt cheap. So Audi has one individual coil per cylinder at $40 each? Adds up for the 6 cylinder. Typical Audi.
Got the flashing CEL yesterday after a very cold start in the snow. Any way to tell which one it is with out OBD equipment?
ANy good sites/threads that walk you through replacing them?
2002 3.0 Q A4 Avant
