Intermittent Start/Stall problem
Old Aug 27, 2011 | 07:18 PM
ONEpointEIGHTtee's Avatar
Default Intermittent Start/Stall problem
Before anyone brings it up, I did search extensively, but didnt find anything matching my exact problem.
2003 A4 1.8t Quattro 5spd
I just bought the car and didnt even have the problem happen to me until my wife mentioned it.
Intermittently immediately after starting, the car stalls. Its a manual trans and I have the car in neutral with the clutch pushed in. Once I start it again its fine. Like I said, it completely starts, and runs at about 1000rpm and then it immediately drop to 0. Its not like its just not starting at all. The engine is definitely running for a second or two.
Old Aug 29, 2011 | 03:49 PM
anyone?
Old Aug 30, 2011 | 04:19 PM
JohnnyMoseley's Avatar
i also have this intermitten problem... same scenario manual trans in neutral starts fine after stall with the rpms just dropping from 1 grand to 0. if you find anything out let me know. i myself have been looking into this problem also.
Old Aug 31, 2011 | 07:48 AM
well I really have no experience with German cars, but if I was diagnosing a GM the first thing Id suspect is the fuel pump. I plan on doing some power upgrades soon, so maybe I'll just replace the fuel filter and upgrade to a walbro 255 and see what happens.
Old Aug 31, 2011 | 12:13 PM
shane.trammell's Avatar
sounds like the engine speed sensor. check the codes.
Old Sep 1, 2011 | 12:04 PM
Is that the same as a crank position sensor?
There are no codes...
Old Sep 2, 2011 | 01:39 PM
has the fuel filter been done?
Old Sep 2, 2011 | 07:57 PM
No. That's the first thing I thought of though. Try to get a new one this week.
Old Sep 3, 2011 | 11:00 AM
I would start with that. Check the pressure at the fuel rail by depressing the schraeder valve on the firewall end with the ignition switched on. There should be a pretty good spray. If there isn't much pressure it's either a bad filter or the fuel pump. There are write ups on the filter and the pump either at audidiy.com or possibly on audizine.
Old Sep 4, 2011 | 10:18 AM
good call shane, but I think Id rather hook up my fuel pressure gauge than just let it spray everywhere, lol.
