Misfire Still...
Old Jun 15, 2009 | 11:00 PM
zippy_gg's Avatar
Default Misfire Still...
Long story short... My car sat on a lot for several months and had a dead battery when I got it back.
On the way to the gas station (tank was on reserve) the car started to misfire and run rough, flashing CEL, etc...
I replaced the fuel filter, had the injectors professionally cleaned, replaced all plugs, and still get misfires. The VAG-com reading complained about # 5 cyl so I swapped coil packs, and still get the same errors...
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUJT68E85A065952 Mileage: 43560km/27066miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E1 909 559 B HW: 8E0 909 059 A
Component: 3.0L V6/5V G 0030
Revision: 00000000 Serial number: AUZ6Z0D0296260
Coding: 0013581
Shop #: WSC 06335 000 00000
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - MIL ON
16689 - Cylinder 5: Misfire Detected
P0305 - 008 - Implausible Signal - MIL ON
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E0 910 155 R HW: 01J 927 156 HT
Component: V30 01J 3.0l 5V USA 3331
Revision: 00000006 Serial number: 00000000592236
Coding: 0001001
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04499
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 06335
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 06335
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00231
Shop #: WSC 22133
WAUJT68E85A065952 AUZ6Z0D0296260
2 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 06335
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1612
Coding: 11788
Shop #: WSC 06335
Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0205
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
2 Faults Found:
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 06335
Address 56: Radio Labels: None
Part No: 8E0 035 186 E
Component: concert II PM6 0410
Coding: 01005
Shop #: WSC 87552
End ---------------------------------------------------------------------
Old Jun 15, 2009 | 11:09 PM
shane.trammell's Avatar
i didnt read all of that bc its greek to me. the misfire didnt follow the coilpack?
Old Jun 16, 2009 | 10:32 AM
zippy_gg's Avatar
Nope! That is what led me to believe there was a fuel delivery issue so I sent the injectors to be cleaned and tested.
The car only has 27k miles on it.
Old Jun 16, 2009 | 10:34 AM
I would check voltage at the cp connector and follow the harness back from there.
Old Jun 21, 2009 | 02:18 AM
djblaize's Avatar
Arrow
Here is what you do, go to any audi or vw dealer and purchase AUDI sparks and coil packs.might be pricey for you, I have 4cl. same thing happened to me after I picked mine up, it was sitting at the dealers for a while. Worked for me and you will save time from getting a new cat put in.
Old Jun 21, 2009 | 02:21 AM
djblaize's Avatar
Oh and did you only swap cl 5? Was told by the dealer that if you are swaping then you need to swap them all.lol (swapping)
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
