Need Help Please
Old Feb 4, 2010 | 07:09 PM
davemes's Avatar
Default Need Help Please
Hey guys im new here but have a problem that i cant quite understand. I have a 2002 audi a4 quattro 1.8t and last night i went to start the car and it wouldnt start. I pushed it home and hooked up my scanner and i got a p0321 code. I went out today and bought a crankshaft sensor and installed it and still no luck. If i leave the car for a bit it will start for maybe a brief few seconds and then shut off. I really need to drive my car adn i have no idea as to whats wrong can some one please help me as soon as possible. Thank you very much in advance.
Old Feb 4, 2010 | 08:18 PM
Dan1969's Avatar
Old Feb 4, 2010 | 08:25 PM
shane.trammell's Avatar
thats the part he said he already replaced. make sure its plugged in well and that the bolt is tight
Old Feb 4, 2010 | 08:40 PM
Dan1969's Avatar
So if after the sensor was install is still giving the same code, then probably a bad connection or bad new sensor.
Old Feb 4, 2010 | 09:02 PM
davemes's Avatar
after i installed the new sensor i cleared the codes and nothing came back but it still wont start any ideas?
Old Feb 4, 2010 | 10:31 PM
Quattros's Avatar
coilpacks?
Old Feb 5, 2010 | 12:15 AM
make sure you have fuel pressure. There is a bleeder valve at the firewall end of the fuel rail. i used a torx bit to make sure i pushed it in all the way when i checked mine last. turn the key to on and then push that in. quite a bit of fuel should come out.
its a schrader valve like a tire has.
Old Feb 5, 2010 | 08:33 AM
Dan1969's Avatar
^^^ so it acts like is flooded?
Old Feb 5, 2010 | 11:34 AM
davemes's Avatar
Well guys i went out and checked for power at the pump. Just to verify it is the 4 pin connector right? I pulled out and checked this connector for power and i got 1.6v , 0.25v, 0.03v and 0.00v this is with the key on. Im guessing that there is a wiring problem to the pump now?
Old Feb 5, 2010 | 02:36 PM
So there's no pressure at the rail??
