Need help replacing coil pack & plugs
Gentlemen, your wisdom and expertese is much needed and incredibly appreciated!!! As my girl and I were driving out to dinner in my 02' A4 1.8T Quattro, my MIL started blinking. Next thing I notice, my idle recieved a kick in the giggle berries and car started vibrating. It would get worse with higher acceleration and working up the gears. After about 2 hours of reading I'm fairly confident it's the coil pack. I am also planning on cleaning the MAF sensor and checking the spark plugs as well. No here is my dilemma, I have yet to tinker under the hood with this car.
Engine coils - Coil Packs (diagnose/replace)
All the how-to forums explain popping off the cover and simply checking and replacing but can't find any pictures. Do any of you have an image/picture on this process??? Can I easily just pop off the cover or do I need a torque set to get 'er off?
MAF sensor (clean)
Same situation. I know I have to remove the airbox and take some stuff apart, but not sure the exact process.
Plugs
What tools will I need to replace mine with NGK BK6RE (recommended by krystallbluea4) and is it a simple process???
Again, can't thank you all enough!!!!!
MAF sensor (clean)
Plugs
Here is what I found about the MAF;
wolfdog; 03-16-2009
The MAF is located under the snorkel leading to the airbox. Follow the air intake from the front grille into the engine bay about a foot or something. Just below it on the right side you will see a plug. That is the plug for the MAF. To confirm you've got the right part, on both sides of the plug there are these tamper proof screws. They require a 5-point tool (like a torx but with 5 not 6 points) that has a hole in the center.
wolfdog; 03-16-2009
Bombguy... You rock! This is exactly what I've been on the search for. It's pouring rain here and no garage or covering to start replacing the coil packs. I was only able to purchase 1 for now and going to attempt process of elimination tomorrow morning.
I really don't want to spend $90 just to it diagnosed and codes read. Is purchasing a $50 code reader simple to plug in a use for a novice?
So this morning after taking off the engine cover I noticed #3 coil pack was elevated about 3/4" higher than all the rest. Once removed it looked horrible. Couldn't remove the spark plug but it looked wrecked also.
What would cause a coil to raise???
Appears there is a recall for all coil packs for 01-07. Sitting at Audi awaiting results of the diagnostic ($119.00) and the free recall inspection. They said it's $99.00 for the spark plugs... Ha!!!
Nice!! "engine misfire" was the issue so they are replacing the coils for free and recommended changing the spark plugs. I said I'd do that myself, thanks.
