need help sputtering problem
Old Mar 7, 2009 | 08:35 PM
baileyb6's Avatar
Default need help sputtering problem
my a4 1.8t has a bad sputtering problem. it runs really rough and sometimes won't even accelerate. ive already changed the mass air flow sensor and the throttle body. it threw a code that said (left bank 1 too lean). i think that was from the vacuum leak. ive already fixed the vacuum leak and its still running like crap. someone please help!
Old Mar 7, 2009 | 08:41 PM
shane.trammell's Avatar
Is the check engine light on? What exactly is it doing (or not doing)?
Old Mar 7, 2009 | 08:55 PM
baileyb6's Avatar
yea the check engine light is on but i havent turned it off after i fixed the vacuum leak. it idles really rough and when i try to accelerate it will start sputting and wont accelerate.most the time when i gas it and it hits about 4,000 rpm it starts shaking and the rpm doesnt move. kinda like a misfire
Old Mar 7, 2009 | 09:05 PM
is the CEL flashing? This definitely sounds like a bad coil, very common problem. Check codes to be sure.
Old Mar 7, 2009 | 09:10 PM
baileyb6's Avatar
cel? your talking about a coil pack right. do those throw a code? because ive heard they do and dont
Old Mar 7, 2009 | 09:11 PM
cel is check engine light. when they are completely out they throw a flashing code. some people talk about them gradually going out and not giving a code, but ive never had that.
Old Mar 7, 2009 | 09:21 PM
baileyb6's Avatar
yes my cel is on but it says (system too lean bank 1) im pertty sure that was from the vacuum leak. and i fixed that.
Old Mar 7, 2009 | 10:07 PM
you could have more than one code stored.
Old Mar 8, 2009 | 12:02 AM
baileyb6's Avatar
yea ill get that looked at in the morning and ill get back at u. i guess if theres no more codes ill buy a coil pack. and swith it out one at a time to c if that fixes it. let me know if u got any more suggestions though.I appreciate it
Old Mar 8, 2009 | 06:09 PM
baileyb6's Avatar
yo i had it checked out this morning and it came back with a new code. (knock sensor) i know the motor isit knocking. i think its from it running so rough. but i cleared the codes ive been driving it all day and the cel hasnt came back on. u still think it could be the coil.
