Need new "material" roof
Old Jul 13, 2010 | 11:08 AM
adsquare's Avatar
Default Need new "material" roof
Does anyone know where to get this from? Water got in somehow and the roof looks so crappy, and i don't want it to smell.
2004 audi a4 1.8t
Old Jul 13, 2010 | 11:59 AM
pa4ul's Avatar
headliner u mean. I think there is a recall for the sunroof drain
Old Jul 13, 2010 | 01:22 PM
02A4kid's Avatar
does anyone have info on the sunroof drain? if there was actually a recall or not? jw...but in my car after it rains and you open the rear doors there is water pooled up on the bottom, not inside the car but where the bottom of the door meets the frame of the car, that little 3" metal strip at the bottom has pools of water i was wondering if anyone has had this problem or knows how to fix it
Old Jul 13, 2010 | 05:49 PM
pa4ul's Avatar
thats normal 02a4kid. wait till the winter sometimes your door will be frozen shut. Good times Good times. Anyway there is a recall from audi on the sunroof drain. Do a little searching on google.
Old Jul 14, 2010 | 11:25 AM
Mr_GoodKat's Avatar
It's more of a "Hey there's a problem we noticed and you need to fix it" than a recall. It's a supplemental to the owners manual and recommends scheduled checks and maintenance on the drains.
If there is damage, you pay for it then submit your claim to the class action lawsuit being filed and basically stand in line to wait...
Old Jul 14, 2010 | 06:40 PM
borninrussia3's Avatar
try getting a used one locally and if you cant check out ebay and other sites if you are going to get it shipped make sure you insure it because they are flimsy little things and you wouldnt want to arrive all screwed up and have no way to return or make your money back. and on the drain note you have to clean them and should do it before you put the new headliner in. also the water pooling in the door sills is fine you should be worried if it doesnt
Old Jul 19, 2010 | 11:04 PM
Windward's Avatar
Yes, this is correct. Just a change to the maintenance schedule to clean the front drains. No recall.
You will need service manual to remove and replace the headliner. Lots of little clips and such. The wiring harness is wrapped in a tar like tape. So unclipping it from the headliner without getting tar on the good side is very difficult. I must have washed my hands 10 times to keep the tar from transferring. Also, it is a bitch to get it in and out of a rear door without kinking it.
