need some help
Old Feb 22, 2014 | 08:21 PM
Ac3's Avatar
Ac3
Default need some help
So started the car this morning just like normal drove around. stopped by my parents house and once I was leaving tried starting the car and it started to sputter and just cut off. Tried it again same thing. It cranks sputters then dies. I have cel and ecp I think? I did just get it recently.
2002 Audi a4 with 125k mi on it. Will be calling the dealer as I haven't had it a week, but thought I'd ask you guys first. Did a search and from what I read looks like it may be fuel pump maf or coil packs can someone help narrow it down
Thanks
Old Feb 22, 2014 | 08:41 PM
Ac3's Avatar
Ac3
Forgot to mention when trying start after first cut off tried giving it gas starting again to get done revs and nothing
Old Feb 24, 2014 | 01:12 PM
pa4ul's Avatar
what codes are you throwing
Old Feb 25, 2014 | 09:54 PM
Ac3's Avatar
Ac3
Don't remember code but it was to do with the cats, took it to the dealer they said cats were clogged, does that make sense?
Old Feb 26, 2014 | 05:24 PM
MKE_Audi's Avatar
clogged cats will do that. exhaust gas can't get out really hurts a turbo engine...
Did you just get the vehicle or just get the CEL?
I would check your spark plugs for proper ignition / burn color. clogged cat is usually due to unburned fuel due to excessive cranking to start it or a fouled plug dumping fuel that doesn't burn. How has your gas mileage been lately?
I had an old Blazer that had a timing issue. If it sat too long it would forget the timing advance value and take forever to start. Eventually I plugged the cat and it bogged down something fierce. I cut open the cat with a grinder, knocked the guts out of it and welded the hole closed. Ran like a champ until I could replace the cat. I don't suggest you cutting open your cat as the Audi is a little more picky about such things than my old Blazer.
Old Feb 26, 2014 | 07:02 PM
Ac3's Avatar
Ac3
Both actually took it to the lot where I got it they told me today that the full pump had gone out too so they're replacing both getting it back in a day or two
