Newbie looking for basic ignition coil help
Old Dec 1, 2008 | 12:49 PM
ashbury's Avatar
Default Newbie looking for basic ignition coil help
Hi, I'm new here and would like to get some help regarding replacing ignition coils.
I have a 03 A4 1.8T with 60K on it and I had one of the ignition coil replaced at an Audi dealership last year (Yes, I was dumb enough to spend the $$$). Now it seems like another coil is about to blow but the CEL hasn't come up yet. Regardless, I'm planning to change the other 3 on my own. I have a few questions below and hopefully you can help me.
1. Do I need to unplug the battery? Anything other than the engine needs to be disconnected/shut off?
2. Is the spark plug right below the coil? Do I need to worry about that when I pull the coils up?
3. I can feel the car shaking when I accelerate but the CEL hasn't come up yet. If I bring it to AutoZone and do a scan will anything show up?
Thank you all for your help and I really appreciate it!
Old Dec 1, 2008 | 12:52 PM
kwik_shift's Avatar
1. Do I need to unplug the battery? NO Anything other than the engine needs to be disconnected/shut off? NO
2. Is the spark plug right below the coil? YES Do I need to worry about that when I pull the coils up? NO Just pull straight up
3. I can feel the car shaking when I accelerate but the CEL hasn't come up yet. If I bring it to AutoZone and do a scan will anything show up? Probably not usually the cel has to be on. Unless your going to scan it w/a vag com.
Old Dec 1, 2008 | 01:08 PM
ashbury's Avatar
kwik_shift, thanks for the quick reply!
Also, do I need special tools to pop the screws off? Thanks!
Old Dec 1, 2008 | 01:38 PM
kwik_shift's Avatar
no but a flat head screw driver will help to unplug the coilpacks.
Old Dec 2, 2008 | 01:41 AM
krystallbluea4's Avatar
On a side note if you are not triggering CEL it's not(99.9%sure) an ignition coil, unless there is something wrong with your CEL. Coil is just a wound conductor, it works or it doesn't. No kinda working allowed.
Old Dec 5, 2008 | 02:25 PM
B6er's Avatar
x2 No middle ground there. Describe the shake. Does the struggle or stutter? A bad inner CV joint can make the car shake on acceleration too.
Musky Cat
Aug 11, 2015 03:34 PM
Kannon
Jan 16, 2011 05:17 PM
b.hasz
Apr 15, 2008 05:03 AM
pavcios
Jul 21, 2007 09:30 AM
