One touch windows
2003 a4 1.8t front passenger side windows one touch isnt working anymore any idea on how to get it back to proper function?
RE: One touch windows
Hold the button for a few seconds after the window is fully up, this will reprogram it for one touch up.
My one touch up works still but the one touch down dosent. any other insights?
Does your window make any popping or grinding noises when you put it up or down?? I'm thinking it could be a warn out regulator, but I may be way off.
or perhaps try the opposite of what the guy said about the one touch up not working... just an idea
My regulator on my old 2001 A4 went out, it makes a clicking sound when the window is going up. Does yours do anything along those lines?
windows got up and down fine. no noises or anything i tried to hold the button their for 10 seconds 15 seconds twenty seconds. nothing. does the key have to be in the on positon or something or off position.
press the down all the way keep it pressed and the up all the way and it will reset or beep confirming it
ok ill try again does it matter if the key is on or the car on or anything>?
ignition on to aux then operarate the windows and ensure they open all the way down ( keep the button pressed ) and do the same to close the system should beep to inform you that its set
