P0299 Underboost issue!
Old Jun 26, 2019 | 08:48 PM
Alexboost's Avatar
Default P0299 Underboost issue!
I was given this car from a friend. 207,000 miles
its has code p0299 Underboost
& p0420 Bank 1
i have replaced the turbo, Diverter valve, n75 valve, boost sensor
i have done a smoke test. From that I replaced a check valve with a hole in it and my intake to turbo tube had a hole. Which is now replaced.
I STILL Have the same 2 dumb codes. Running out of ideas
clogged cat? MAF Sensor? New engine haha
Old Jun 27, 2019 | 05:58 PM
kjopen's Avatar
Hi,
I've checked my logs and these are the codes I had:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
16804 -
P0420 - 002 - Please Register/Activate - Intermittent
I eventually replaced my Cat and at the same time inspected my Turbo, the flapper wasn't sealing correctly - so adjusted the flapper nuts. My fault then cleared and the car is much faster, so the combination of a blocked Cat and wastegate flapper solved my issue. FYI: I fitted a cheap Cat from ebay - it's been fine but only expect a year or so out of it - will then buy another rather than dealer prices....
Old Jan 6, 2025 | 12:18 PM
PercivalShortz's Avatar
& p0420 Bank 1
Old Jan 7, 2025 | 12:28 PM
& p0420 Bank 1
i have replaced the turbo, Diverter valve, n75 valve, boost sensori have done a smoke test. From that I replaced a check valve with a hole in it and my intake to turbo tube had a hole. Which is now replaced.
no news ?
Wruce Billis
Feb 2, 2019 06:39 PM
kilohertz
Nov 13, 2018 09:51 PM
mk4cam
Aug 18, 2013 06:25 PM
andrewwm
Jul 9, 2013 12:09 PM
Noobinator
Jul 13, 2007 08:31 PM
