P0411 2002 audi a4 quattro
Old Sep 21, 2011 | 02:41 PM
hagi10's Avatar
Cool P0411 2002 audi a4 quattro
I'm kind of new to this forum, but I need some help with the code P0411 "Secondary Air Injection System Incorrect flow detected",seems like I get this code all the time when I wash my car, or if it is raining outside,I did some research on this site and others, but the one thing I have not seen, is if there is a schematic someone has on how this whole thing works, I checked in the Audi owners manual, but not much is there I can go by,also lots of other forums I was reading, but seems like nobody has an answer for it, any help would be appreciated
Old Sep 21, 2011 | 05:47 PM
pa4ul's Avatar
i would check all your vaccume lines first. Including check valves. U might have a vac leak in ur system.
Old Sep 21, 2011 | 09:28 PM
hagi10's Avatar
Cool p0411
Originally Posted by pa4ul
i would check all your vacuum lines first. Including check valves. U might have a vac leak in ur system.
Thanks pa4ul for the quick reply
I did check all the vacuum lines,and they all look in good shape, but why is this code (p0411) is coming up just when I get a car wash or when is raining outside ???
Old Sep 22, 2011 | 11:56 AM
pa4ul's Avatar
no to sure did u make sure the check valves arent getting corrided away. i know at one point i had a studder and couldnt seem to find a hose with a leak. Then i checked under the manifold and the check valve was half way corrided away.
Old Sep 23, 2011 | 01:59 AM
hagi10's Avatar
Cool
Check valves are all in perfect like new condition, but I think the problem might be that I noticed one of the U pipes is cracked underneath the intake manifold, will have to find one of these U pipes and see what happens, hopefully that is the problem, I don't have a picture right now to show, but I will make one
escape
Apr 25, 2015 06:33 PM
chrisrogers86
Jul 8, 2014 02:00 PM
ypcyrl
Dec 13, 2013 09:50 PM
p_smith
Jul 12, 2010 07:08 PM
sophik
Jul 9, 2008 05:55 PM
