Please help!!!!!!
Old Sep 9, 2013 | 03:55 AM
ScottyJay5's Avatar
Exclamation Please help!!!!!!
Hey guys new here with a recently purchased 2003 Audi a4 1.8t Quattro. So im having a huge problem not getting any spark, the car will not start cranks just fine but will not spark. I recently replaced crankcase vent valve. Last week the radio did the backlight thing so I tried disconnecting the battery, now the car wont start radio wont turn on (I was having rough starts before I disconnected battery). I light checkd all fuses including the ones next to the ecu. I need help please it is my only means of transportation!
Old Sep 9, 2013 | 06:48 AM
tofast2belast's Avatar
god dam have you learned what ( , . ? ; ) are? itl do wonders if you learn that first.
ok after deciphering the paragraph, first did you reconnect battery? you said you disconnected it so check that. then check the 'break' fuse on the positive terminal connector to the battery.
and what you talking about radio did the backlight thing?
Old Sep 9, 2013 | 08:47 AM
ScottyJay5's Avatar
sorry I typed this in a hurry. and yes the battery is connected firmly. and it was doing the thing where it will always stay on but will not fully turn on, or come up in safe mode. search it and it will come up I guess its a common problem said to disconnect battery did not work for me.
Old Sep 9, 2013 | 08:54 AM
ScottyJay5's Avatar
I also did not find a fuse on my battery terminal
Old Sep 9, 2013 | 01:35 PM
pa4ul's Avatar
have u made sure the bat is fully charged??
Old Sep 10, 2013 | 06:51 AM
look for this
http://www.capav.com/Audi/Misc/Battery_Main_Fuse.jpg
Old Sep 11, 2013 | 05:01 AM
ScottyJay5's Avatar
no I have not tried checking for a full charge but wouldn't the car not crank if not fully charged? and the fuse is good.. it cranks and acts like it is going to start just wont spark man im lost idk what too do
Old Sep 11, 2013 | 06:58 AM
check and replace spark plugs, coil packs, and try unplug the maf sensor and try to start.
do you have a check engine light?
Old Sep 12, 2013 | 04:17 AM
ScottyJay5's Avatar
No check engine light and I've checked coil packs and spark plugs ill try replacing this weekend anyother suggestions? Thanks for the help btw
Old Sep 13, 2013 | 02:31 PM
pa4ul's Avatar
so u are cranking right? Have u checked the presure at the fuel rail?
