Power Steering question
Old Oct 21, 2009 | 10:17 PM
CYLax's Avatar
Default Power Steering question
I have a 2003 3.0 with 100k miles and noisy power steering system...but it only seems to happen when it's cold outside. The rack was replaced under warranty by the dealer last April and I have gone through the bleed process described in the common problems thread. Fluid level looks good.
I bleed the system at least once a week and i continue to get air in the system. Where is the air coming from? It doesn't seem right to have to bleed the power steering so often.
The noisy system really only shows up when the temps drop below 40 F...the colder it gets, the louder the noise.
Any help is greatly appreciated.
Old Oct 22, 2009 | 12:51 AM
mikeeace's Avatar
Member
Just had the same problem, check the fluid, also check the hose line that goes from your pump to the top the the engine.. it would connect by the audi symbol... just follow the hose.. there could be a small leak where air is getting in.. i just got my car back yesterday and thats what the problem was. hope this helped and good luck
Old Oct 22, 2009 | 10:24 AM
CYLax's Avatar
Thanks, I'll give that a try!
Old Oct 22, 2009 | 10:29 PM
Cas1985's Avatar
cylax, i have the exact same problem. i became curious after i had the system flushed and it didn't fix it.
i'm gonna try the solution the above poster suggested and see what i can find.
Old Oct 23, 2009 | 01:54 AM
Dan1969's Avatar
There's several posts like this accross different forums. I'd check for fluid level and then check for leaks. After that you need to let your car warm up at least 3 minutes on the cold weather to let the power steering coolant lines warm up.
Old Oct 23, 2009 | 09:59 AM
CYLax's Avatar
Thanks for the tips. I did quite a bit of searching on this topic prior to posting...my fluid level is in good shape and there are no leaks that I am able to find. On cold days, my car always gets a 3-5min warmup before I go anywhere...on warm days I always let her run for a minute or so before moving.
Hopefully I'll have some time tonight to take a look at the line and see if it helps.
Old Oct 23, 2009 | 11:27 AM
Cas1985's Avatar
cylax, once again my car does the same as yours. i have an 02 3.0 quattro and my fluid level is also good. i'll try to look at it myself this weekend, hopefully tonight and i'll post what i find.
Old Oct 24, 2009 | 12:30 AM
Dan1969's Avatar
If you have the noise and everything else is good, maybe your steering rack or pump are going out.
Old Oct 26, 2009 | 07:57 PM
Markow123's Avatar
Member
I just experienced and was going to post about this problem myself today!!
Was going to give someone a ride to the airport and was nervous to take my car since i turned it on and when i'd turn it was making this sound.
Is this an expensive fix to just do at a shop? I'm going in to get one my rear windows fixed anyway. Any help would be nice.
Can't believe this is a common problem, how strange =/
'03 car has 75k miles
Old Oct 27, 2009 | 09:31 AM
tdoyle's Avatar
I saw another post on thsi topic in another forum, a random reply suggested adding ATF to the PS fluid and that it would address the issue. While I'm all for saving $600+ on a pump replacement I'm more than a little hesitant about doing this without someone else chiming in. Why would someone recommend adding ATF to the PS fluid and why would it help?
If it would actually help, what ATF could be used to safely mix with the OEM fluid? If there is one thign I've learned since buying this car its that other than gas, virtually none of the fluids seem to the same as you mgiht find in a regular Autozone shelf.
