Rear Brakes~~~Please help ASAP
Old May 10, 2008 | 04:37 PM
M¥§T's Avatar
Default Rear Brakes~~~Please help ASAP
Hey guys,
I'm trying to replace my rear rotors and pads...but I can't seem to get my rear calipers to compress so that I can put the new pads on. Do I have to release the parking brake cable or something along those lines to release some pressure? I already have the cap for the fluid off. I'm hoping there is something that I am missing and that my calipers aren't seized. Both sides are exactly the same way. The pads weren't completely worn either, I was just replacing them because I figured if I did the front I might as well to the rear as well.
Any help would be great, since my car is currenlty jacked up in my driveway without rear brakes...
PS. The parking brake is off.
Thanks,
Mike
Old May 10, 2008 | 05:23 PM
nihil's Avatar
Default RE: Rear Brakes~~~Please help ASAP
You need to turn the pistons as you compress them. There is a special tool for it you can borrow from AutoZone for a $30 deposit.
Old May 10, 2008 | 05:43 PM
M¥§T's Avatar
Yea, turned out the problem was the tool i had borrow was busted, when you put pressure on it, it locked up, went to pep boys and got another tool and all is good again. Thanks for the reply nihil
gillahoon
Feb 9, 2014 01:38 PM
BALLHAWGG
Mar 27, 2012 02:55 AM
csb
Jan 30, 2012 03:36 PM
bomber495
May 26, 2011 01:57 PM
