Rough idle and low compression
03 1.8T Quattro Auto 87k
Rough idle and low compression, drives fine. I put new plugs, coil packs, cleaned the TB, MAF and tested the fuel injectors to see if that would fix my rough idle, it didn't. After doing that I got a compression test done. Cyl1 Comp 150 Cyl2 Comp 150 Cyl3 Comp 115 Cyl4 Comp 120 Codes are: P0300 P0301 P0302 P0303 P0304 What's wrong and is there any way to fix this? |
