slave cylinder install--2003 a4 1.8t
All:
I have been putting the slave cylinder back on and CANNOT get it compressed enough to have the hold down bolt go into the transmission. The question is if i pull the hydraulic line so that I dont have to compress the hydraulics, will it be easier to install (and yes, then I will have to bleed it). Aother way to look at it is, does the slave cylinder have an internal spring that forces the piston out??
Thaks in advance foor your help.
